Bruce Kieffer Posted October 16, 2017 Share Posted October 16, 2017 It seems that snap to grid only works in top/plan view. Is there a setting to make in work in other views? Quote Link to comment
zoomer Posted October 16, 2017 Share Posted October 16, 2017 That's a real problem for me. Especially as Curtain Walls aren't very optimized to edit their Grid in Top Plan View. And I would like to snap to a Grid in any orthogonal View too. Quote Link to comment
Art V Posted October 16, 2017 Share Posted October 16, 2017 Yes, it would be nice to have snap to grid work in orthogonal views as well, basically in any 3D view where you can choose whether the Z-axis grid should be snappable or not (in case you only want to snap to X/Y for positioning on a horizontal area or any surface in the X/Y plane in a tilted view for that matter). Or have snap to each axis to be on/off per axis. Quote Link to comment
zoomer Posted October 16, 2017 Share Posted October 16, 2017 Would be cool to have a separate grid setting for each of X, Y and Z axes Quote Link to comment
halfcoupler Posted October 16, 2017 Share Posted October 16, 2017 (edited) Don't know if this is a good workaround, but it should be quick and easy to create a grid of loci via the dublicate array tool and have this on a separate layer. The grid can then have any desired shape in this way and it will snap in 3D. Edited October 16, 2017 by halfcouple Quote Link to comment
zoomer Posted October 16, 2017 Share Posted October 16, 2017 You are right. But beside that snapping to geometry in those current "3D" orthogonal Views will make you always unwanted jump in 3rd Axis direction, I normally use a typical (industrial) 1,20 m visible Grid together with a 0,30 or 0,10 m snapping Grid. (Additional to my usual, manually drawn, 7,20 m Column Grid, its with potential abnormalities) Quote Link to comment
Bruce Kieffer Posted October 16, 2017 Author Share Posted October 16, 2017 (edited) So I guess the answer is no, there is no way to snap to grid in any view other than top/plan? Edited October 16, 2017 by Bruce Kieffer Quote Link to comment
Bruce Kieffer Posted October 16, 2017 Author Share Posted October 16, 2017 I just found a workaround, and now I remember that I have used it before, but even so it would be nice if the grid snapping just worked in the other views. The workaround: Switch to screen plan and turn off snap to object. Quote Link to comment
zoomer Posted October 16, 2017 Share Posted October 16, 2017 As far as I remember, Grid is shown and snap able in 3D Isometrics. Maybe in front/left/right/back too you just can't see the Grid beside than a line And not to forgot that (in eralier VW versions ?) you could restrict the Grid Display to paper size (gone now ?), or infinite as I preferred, but in 3D it always was limited by paper size. That is why I use a funny document paper size of about 5,80 m x 3,80 m, to make my Grid available for the whole building, which for me is normally located between positive X and positive Y Axis only. So pity to have to waste ¾ of my Grid useless. Quote Link to comment
Bruce Kieffer Posted October 16, 2017 Author Share Posted October 16, 2017 I do find that if I select a center edge point and I use it to resize, and I shift my mouse off center while resizing, then I see the grid snaps as I pass through them, but my object must be aligned to the grid first to make this work. Quote Link to comment
zoomer Posted October 16, 2017 Share Posted October 16, 2017 yes, object snaps normally have priority and it should work to align such an edge to the grid. if you want to align a object to the grid you have to zoom in. I also experienced that when zoomed out you picked the grid and moved the object by grid distance instead of aligning. strange .... Quote Link to comment
