Problem: Containers are not respecting their classes and 2D stuff inside lighting fixtures is rotating oddly.
Details:
In the source file everything looks fine and works well. The attached clips are of a rotated light on a vertical pipe position. No funny stuff yet to do the booms laid out. See the first 2 images.
My work was done on top of a rotated base. I'm just trying to make things easier for the ACAD tech to import the theatrical stuff back into their background files. To export this I referenced this file into a non-rotated file from the architect, which required rotating the viewport. And I got the 3rd image. Legend classes are all off. The text in the fixture symbol is aligned center-center, not that it should matter. Setting the text rotate option just spins the text inside the circle.
I triple checked the container objects, label legends, class settings, etc.
I tried this in both 2017 SP4 & 2018 SP1. Same stupidness.
RickR
Details:
Any ideas?
0 answers to this question
