IFC Export Setting in a Project Sharing file
Hi!
I'm working in a Project Sharing file and trying to export to IFC. It seems that the data that is entered into the Export IFC Project dialog will only stay in the same working file that it is in. Even when I also commit the setting to the project file, it does not show up in the other working files or in new working files created from the master.
Does anyone have experience how to save the IFC Export Setting to the Project Sharing master file?
Regards,
Taavi
  • 2 weeks later...
It seems I managed to solve this problem. You have to convert the project file back into a regular VW document, make the changes to the IFC settings there and turn this file into a project file again. Then the IFC settings set in the regular document will always show up in the working files. Kind of tedious, but better than nothing.
