Dubman Posted October 12, 2017 Share Posted October 12, 2017 Have problems with door symbols inserted into component walls & not giving wall breaks even with the symbol set as full break with wall caps. It really sucks to have to add a line afterwards to both sides of each door. Any suggestions, I know I have fixed this problem before, but can not remember or do it again. Thanks! Quote Link to comment
Diego - Resuelvector Posted October 12, 2017 Share Posted October 12, 2017 The door you're using is a custom symbol or is a Vectorworks default plugin door? Quote Link to comment
Dubman Posted October 12, 2017 Author Share Posted October 12, 2017 Yes it is, but it is working fine on another computer in the office with same version of windows & vectorworks with all settings the same. Computers are both Dells & built verify similar. Quote Link to comment
Dubman Posted October 18, 2017 Author Share Posted October 18, 2017 I figured it out on the computer I'm using, under the edit wall style, Edit Wall Attributes tab, Wall Caps, Use Component line attributes . Now I will see if it works on my co-workers computer Quote Link to comment
