zoomer Posted October 11, 2017 Share Posted October 11, 2017 Window Styles behave strange for me in VW 2018 SP0-1 1. Changing Styles Windows in Walls do not update reliably. Sometimes I need to pull them out of the Wall and back in. (Not 100% sure on this, could maybe be a editable Style Setting Component, but for sure I had cases where pulling out/in updated my Window) 2. Duplicating Styles May destroy/corrupt their Preview generation in Style Settings dialog. And therefore RM thumbnail and preview too. 3. a) Corner/Non Corner Windows Window Mode : Fixed Glass (Jamb+Sash+Glass) I use a Sash Depth Offset. As soon as some Windows, using that Style, are set to Corner Mode, this Offset will be ignored, sometimes even set to 0,00 in Style. All Windows will lose Sash Offset, not just Corner Mode Windows. 3. b) Corner Window : Sash Offset is controlled by Corner Settings "Corner Condition > Mode : "Corner Post", only (!), although I don't use that Mode but Flush Glass. This is the only Mode to set an Offset - but determins Sash Offset in general, when Corner Mode active for any of that Style's Windows ! Quote Link to comment
0 zoomer Posted October 11, 2017 Author Share Posted October 11, 2017 (edited) Forgot the most important : 4. Updating Styled Windows (only 3-15 Windows in Walls per Style (3), distributed over 4 Stories/Layers) takes much to long ! Described in real world units that means about 12-15 seconds for getting 5 Windows updated. Which feels like the amount of time needed to select and change 5 Windows manually separately in OIP, if that would work in realtime. I can't remember having noticed such delays before so I would assume that is new to VW 2018. Edited October 11, 2017 by zoomer Quote Link to comment
0 zoomer Posted October 12, 2017 Author Share Posted October 12, 2017 Well, updating a Column Style, used by 176 Columns over 4 Layers takes about half a minute here. That is unrealistically too long for realistic work. And here comes my UI wish, Everything that takes langer than 1 Second - needs a Progress Bar. Quote Link to comment
zoomer
1.
Changing Styles
2.
Duplicating Styles
3. a)
3. b)
2 answers to this question
