markdd Posted October 10, 2017 Share Posted October 10, 2017 Any Spotlight users having problems making the straight and curved truss tools work in 2018 sp1? 1 Quote Link to comment
0 Industrial Event Services Posted October 12, 2017 Share Posted October 12, 2017 (edited) Yes. After installing SP1 the straight/curved truss tools do not function. This seems to only occur in a drawing started in VW 2017 and imported to VW 2018 first release. Does not occur in a new drawing started in 2018 SP1. Workaround for me was to simply copy and paste objects from a blank drawing or the existing drawing. Edited October 12, 2017 by Industrial Event Services Quote Link to comment
0 markdd Posted October 12, 2017 Author Share Posted October 12, 2017 Tech support in the UK suggested a reset of my user folder which fixed the problem. Quote Link to comment
0 Kevin McAllister Posted October 14, 2017 Share Posted October 14, 2017 I'm having this issue. Existing trusses disappear if you edit them and I am unable to even select the Curved Truss tool. Each time I do VW reverts back to the selection tool. Nothing like unreliable software when you have revisions with a short turnaround window. I ended up ungrouping the correct size truss in VW2017 and importing the geometry into VW2018 to make things work. Sigh. SP1 is turning out to be less reliable than SP0. Doesn't anyone beta test before releasing anymore.... Kevin Quote Link to comment
0 markdd Posted October 14, 2017 Author Share Posted October 14, 2017 (edited) I have had it sorted by tech support in London. Here is the routine. It’s a reset of the User folder: Go to your VW preferences. In the user tab click the button that says “reveal in finder”. This will get you to the location of your user folder. Close Vectorworks By default the user folder is called 2018. Drag it to your desktop leaving nothing behind. Vectorworks will rebuild the folder when restarting. Restart VW. You will need to allow it to re register you so you will needs to be online. A “fresh” version of VW will restart and the Truss tool should work now. After that I slowly rebuilt the user folder one folder at a time from the copy on the desktop, starting with the plugins and workspace folders. That pretty much got me back to where I was before. Restart the programme after every file restore. You will need to redo your user preferences again though which is a bit of a bore although there is an XML file for that somewhere which I guess you could also restore. Keep checking that the Truss tool still works though. I don’t know where the “corrupted” file is that caused the problem in the first place. Edited October 14, 2017 by markdd 1 Quote Link to comment
0 Wesley Burrows Posted October 14, 2017 Share Posted October 14, 2017 1 hour ago, markdd said: I have had it sorted by tech support in London. Here is the routine. It’s a reset of the User folder: Go to your VW preferences. In the user tab click the button that says “reveal in finder”. This will get you to the location of your user folder. Close Vectorworks By default the user folder is called 2018. Drag it to your desktop leaving nothing behind. Vectorworks will rebuild the folder when restarting. Restart VW. You will need to allow it to re register you so you will needs to be online. A “fresh” version of VW will restart and the Truss tool should work now. After that I slowly rebuilt the user folder one folder at a time from the copy on the desktop, starting with the plugins and workspace folders. That pretty much got me back to where I was before. Restart the programme after every file restore. You will need to redo your user preferences again though which is a bit of a bore although there is an XML file for that somewhere which I guess you could also restore. Keep checking that the Truss tool still works though. I don’t know where the “corrupted” file is that caused the problem in the first place. I did what Mark is suggesting and it fixed it for me. Quote Link to comment
0 Kevin McAllister Posted October 15, 2017 Share Posted October 15, 2017 21 hours ago, markdd said: I have had it sorted by tech support in London. Here is the routine. It’s a reset of the User folder: Go to your VW preferences. In the user tab click the button that says “reveal in finder”. This will get you to the location of your user folder. Close Vectorworks By default the user folder is called 2018. Drag it to your desktop leaving nothing behind. Vectorworks will rebuild the folder when restarting. Restart VW. You will need to allow it to re register you so you will needs to be online. A “fresh” version of VW will restart and the Truss tool should work now. After that I slowly rebuilt the user folder one folder at a time from the copy on the desktop, starting with the plugins and workspace folders. That pretty much got me back to where I was before. Restart the programme after every file restore. You will need to redo your user preferences again though which is a bit of a bore although there is an XML file for that somewhere which I guess you could also restore. Keep checking that the Truss tool still works though. I don’t know where the “corrupted” file is that caused the problem in the first place. Thanks Mark. I often follow those steps when VW acts up. I've already done it once for VW2018. This will be the second time hence my frustration. This year was the first time I used the Migration Manager. I only used it to move my 2017 workspace, nothing else, but I suspect this it the root of my problems. Kevin Quote Link to comment
0 MeTheMachine Posted October 16, 2017 Share Posted October 16, 2017 The steps outlined above did not resolve my truss tool problem, so I went the extreme route. - I have uninstalled VW 2018 completely. - Reinstalled 2018. Changed no settings, nor loaded any Preferences. Kept everything default. - Tried Truss tool and it worked. - Installed SP1. Once again, changed no settings, nor loaded any Preferences. - Tried Truss Tool and it FAILED. Will have to uninstall and this time around will not update to SP1. Any other suggestions? Quote Link to comment
0 Industrial Event Services Posted October 17, 2017 Share Posted October 17, 2017 Thanks Mark. Resetting the user folder also worked for me. Quote Link to comment
0 dbrumbach Posted October 27, 2017 Share Posted October 27, 2017 Thanks Markdd, Resetting the user folder did allow the truss tool to work, as well as make older symbols visible that I created with the truss tool pf previous VWX versions. I agree with Kevin though, this SP should have been reviewed and thoroughly tested to ensure everything is working properly..... db Quote Link to comment
markdd
9 answers to this question
