digitalcarbon Posted October 6, 2017 Share Posted October 6, 2017 is this possible? Quote Link to comment
digitalcarbon Posted October 6, 2017 Author Share Posted October 6, 2017 also, IF you did not want to export symbols but just wanted to do a part drawing of a symbol IN Vectorworks THEN we should be able to viewport to sheets JUST symbols alone w/o having to place them on a layer. 1 Quote Link to comment
digitalcarbon Posted October 6, 2017 Author Share Posted October 6, 2017 when exporting a symbol, the export should use the same name as the name of the symbols in VW currently i have to type in the name...and as you can see i did not get it correct...so i have to do it again 1 Quote Link to comment
digitalcarbon Posted October 6, 2017 Author Share Posted October 6, 2017 playlists org vs what we have now Quote Link to comment
digitalcarbon Posted October 6, 2017 Author Share Posted October 6, 2017 a bit more Quote Link to comment
digitalcarbon Posted October 9, 2017 Author Share Posted October 9, 2017 (edited) note how Onshape allows making a direct View Port of a "Symbol" to a drawing sheet VW should do the same with symbols. along with the ability to batch export symbols (i know...i'm repeating myself but its becoming more clear as i continued to work on this) Edited October 9, 2017 by digitalcarbon Quote Link to comment
digitalcarbon Posted October 9, 2017 Author Share Posted October 9, 2017 again, below is a list of all parts that need to be manufactured in HDPE. need to export too... in this case I'm doing this work "in house" & to Onshape. Still, at other times, i may need to export all this to a fabricator and their cad system. Quote Link to comment
Benson Shaw Posted October 9, 2017 Share Posted October 9, 2017 On 10/6/2017 at 4:50 AM, digitalcarbon said: also, IF you did not want to export symbols but just wanted to do a part drawing of a symbol IN Vectorworks THEN we should be able to viewport to sheets JUST symbols alone w/o having to place them on a layer. Design community used to be mostly focused on drawing for presentation with paper output - just make it look right for interpretation by clients, consultants, builders, fabricators, etc. Today's 3d models are super capable virtual reality and can be interpreted for or even directly drive machinery for fabrication and construction. I really hope Vectorworks is working up a fantastic workflow and interface aimed at direct field use of the model for clients, consultants, and fab/install processes. It's transition time, so we'll still often need current usage of sheets, dimensioned drawings, renders, etc. Quote Link to comment
