Nico_be Posted October 3, 2017 Share Posted October 3, 2017 Helo everybody, When i copy-paste a marionette wrapper from a file in milimeters in another file in centimeter, the marionette objet is very very small. Scaling the objet or changing text size as no effect on the size. Do you know how to do? Thanks! Nico Quote Link to comment
DomC Posted October 3, 2017 Share Posted October 3, 2017 (edited) Hi Do you mean the size of a Wrapper or the size of the network inside your wrapper? Can't confirm this with VW 2017, a wrapper's width (the wrapper-node width) is always about 10% of a DIN A4 width independent of the document unit Marionette Objects are page based. Maybe your layer scale is not the same and you run into this one: https://forum.vectorworks.net/index.php?/topic/51667-marionette-node-scale/ You could first change the layer scale like your target layer scale and then copy/paste. Or scale the content of your wrapper with the scale difference. If your created objects are too small, check your input values, maybe they changed by copy/paste to default or you are not using dim input nodes for size-values (In this case it should be bigger not smaller with cm). Edited October 3, 2017 by DomC Quote Link to comment
Nico_be Posted October 4, 2017 Author Share Posted October 4, 2017 Yes, indeed, it's a layer scale problem. Thanks! Quote Link to comment
