Chris Gentry
DMX Input Identifier
Is there a way to turn these off so that they don't render?
I see that the objects are classed but making the class invisible doesn't seem to have an effect.
Edited by Chris Gentry
turning off the Input classes is supposed to turn them off, if you are not seeing this could you upload a file to check please.
Ok, it appears it's not working on particular instruments. So far the ones I've come across that aren't working are the GLP Impression X4s's.  I was able to turn off the ID's in the edit symbol mode but once I came back out to the doc, they were still on.
Seems that the 3D is miss classed, if you edit and change it to the 3D input class it should be fine.  we will fix it here, but may be a while till it gets out to the users.
