Chris Gentry Posted October 2, 2017 Share Posted October 2, 2017 (edited) Is there a way to turn these off so that they don't render? I see that the objects are classed but making the class invisible doesn't seem to have an effect. Edited October 2, 2017 by Chris Gentry Quote Link to comment
Chris Gentry Posted October 2, 2017 Author Share Posted October 2, 2017 14 minutes ago, Rob Books said: turning off the Input classes is supposed to turn them off, if you are not seeing this could you upload a file to check please. Ok, it appears it's not working on particular instruments. So far the ones I've come across that aren't working are the GLP Impression X4s's. I was able to turn off the ID's in the edit symbol mode but once I came back out to the doc, they were still on. Quote Link to comment
