SCParker Posted September 26, 2017 Share Posted September 26, 2017 If I move a hoist away from it's original insertion point, it lets go of the truss. Is there a way of reattaching it? Rather than deleting and using the hoist tool to insert a new one? THanks, Scott Quote Link to comment
Guest Beckstorm Posted September 26, 2017 Share Posted September 26, 2017 If you bring the hoist back to the truss you will get a centerline that you can snap to, this will reconnect the hoist. The trick is your mouse needs to be over the geometry of the truss so having simplified 2d on makes this easer. Quote Link to comment
SCParker Posted September 26, 2017 Author Share Posted September 26, 2017 Hmm. When I select a truss and then select "select system objects" in the OIP, the hoist gets selected/highlighted along with the truss. After I move the hoist, even though I snap to the red centerline, choosing "select system objects" in the OIP leaves the moved hoist out of the selection. Quote Link to comment
Guest Beckstorm Posted September 26, 2017 Share Posted September 26, 2017 This looks to be a bug I will put this in now. Thanks @Scott Parkerfor finding this! Quote Link to comment
SCParker Posted September 26, 2017 Author Share Posted September 26, 2017 Thanks. Just filed 145894 Quote Link to comment
