ykong222 Posted September 24, 2017 Share Posted September 24, 2017 Every ETC symbol has the same beam and field angle. In edit mode, angle is right. How can I fix this problem?? Quote Link to comment
JBenghiat Posted September 24, 2017 Share Posted September 24, 2017 Open Lighting Symbol Maintenance in the Spotlight>Paperwork menu. If all the data data is correct, click the Update All Lighting Devices menu, and click OK. All of the Light Info data will push out to existing lighting devices. Quote Link to comment
ykong222 Posted September 24, 2017 Author Share Posted September 24, 2017 Thank you for your reply~ I did what you told me to do but It didn't work. Quote Link to comment
ykong222 Posted September 24, 2017 Author Share Posted September 24, 2017 I've changed some of the infos in edit instrument data. Everything has changed except the angle. Hmmm .... Quote Link to comment
JBenghiat Posted September 24, 2017 Share Posted September 24, 2017 Are your symbols referenced? What exactly were the steps you took to edit the data? Quote Link to comment
ykong222 Posted September 25, 2017 Author Share Posted September 25, 2017 (edited) PIC #1~#4 I've done what you told me to do. PIC #5~#9 I've edited the data. All the angles has been changed to 0.0 deg. PIC #10~#14 I've edited the angles in 2D Component edit which the angles were 0.0 deg already. And then the angles in Lighting Symbol Maintenance has been changed automatically. But the symbol data was the same. PIC #15 I've changed the data in Object Info. window. I know that it is the best way to put the right information in the symbol. But it will be so annoying if I have to change all the angle infos everytime : ( Any clue of this problem? I just tell you that I've clicked the Update All Lighting Devices menu few time to see what happens. It didn't work. It happens all of my students too. Your program is working well? Thank you for your time : ) Edited September 25, 2017 by ykong222 Quote Link to comment
ykong222 Posted September 25, 2017 Author Share Posted September 25, 2017 (edited) I've downloaded VW 2017 educational version for class. And All my students have the same problem. I've asked Korean distributor about this problem. They said that the same thing has happened with their non-educational version program. You never had this problem ... hmmm ... it is strange. I will talk to the korean distributor about this issue and i hope that i can find the reason. Thank you : ) Edited September 25, 2017 by ykong222 Quote Link to comment
JBenghiat Posted September 26, 2017 Share Posted September 26, 2017 Is your version localized? (Your distributer should know) Your screen shots all appear to be in English, but some component may have been changed that is preventing Light Info from reading properly. Quote Link to comment
