Tom Klaber Posted September 24, 2017 Share Posted September 24, 2017 I am trying to set up a homemade issue managing drawing list. The built-in one is too finicky. So - I have created Sheet Data boolean fields - ISSUE 1, ISSUE 2, etc. Now I am trying to create a sheet list, and I want to automatically show an ● if that issue is True. VW's built in sheet uses: =IF('Title Block Issue Data-1'.'Number'<>'', '●', '') to do the same thing that references the built issue manager. I am trying to modify it to reference my boolean Issues, but I can not get it to work. Here is what I have: =IF('Title Block Sheet Data'.'ISSUE 1'.'True', '●', '') Can anybody see what I am doing wrong? Is boolean the wrong thing to use here? Quote Link to comment
0 michaelk Posted September 24, 2017 Share Posted September 24, 2017 It's easier than that. If the field is really a boolean field and not a text field that says either "TRUE" or "FALSE": Select one of the fields in the boolean column > Right Click > Format Cells… > Number Tab > Check Boolean on the left side > On the right side enter the values you want displayed for true and false. 2 Quote Link to comment
0 Tom Klaber Posted September 24, 2017 Author Share Posted September 24, 2017 So much easier. Duh. Thank you! Quote Link to comment
Tom Klaber
2 answers to this question
