zero Posted May 13, 2004 Share Posted May 13, 2004 Hi All well I've done enough workspace editing to be quite good at it; VW9 to VW10 to VW10 Australia/NZ to VW11 to VW11 Australia/NZ So I went to "Object context", selected send-to back, then clicked the radio button for CTRL. Next I added a B. VW said "The shortcut "CTRL+B" is already used by: Send to Back. Do you want to reassign the key to "Send to Back"?". And of course I clicked yes, and now it won't work at all. And I can't make it work now at all in my custom workspace, although for all other workkspaces it is fine. Must be a bug I think. Quote Link to comment
Guest Posted May 13, 2004 Share Posted May 13, 2004 It sounds like you have two send to back menu options in your workspace. Quote Link to comment
zero Posted May 19, 2004 Author Share Posted May 19, 2004 It does Katie... How does one fix it please? Mat Quote Link to comment
Guest Posted May 19, 2004 Share Posted May 19, 2004 Use the workspace editor to eliminate the duplicate. You should remove both and re-add to your workspace. Quote Link to comment
