It would be very helpful if the data fields, at least the user-generated ones, for Title Block Border objects (e.g. Sheet Data fields) could be re-ordered, since the sequence of entry definitely affects the efficiency of the workflow. You may want to add a new field at a later time but have it adjacent to one of the earlier fields, and currently there's no way to accomplish this, short of deleting all of the fields in between and then re-creating them after you've added the new one you want.
The setup of these data fields (creation, deletion, re-ordering) should also be separate from the production data input! It's highly undesirable for a user to be able to accidentally delete a data field or change a Title Block Border from styled to unstyled when you're just trying to enter project, sheet, or issue / revision data.
Markus Barrera-Kolb
Cheers,
Markus
Edited by Markus Barrera-KolbLink to comment
1 answer to this question
