lisagravy Posted September 19, 2017 Share Posted September 19, 2017 I have created a pad from a closed 3d polygon, which varies in height along a curve on my model. When I update my site model, one edge of the pad acts as I expect it to - the road ramps down to meet the edge of the pad. However, I then expect the inside of the pad to form ground level, and for the site levels on the other side of the pad to meet the edge of the pad - which doesn't' happen? Instead, I get a cliff edge.... can anyone help me with what I'm missing? Quote Link to comment
J. Wallace Posted September 19, 2017 Share Posted September 19, 2017 There are a number of things that can cause this. Check that your site model settings have the correct use site modifiers on...can't tell you how many times I've placed a modifier in a drawing and this setting was incorrect. Check your grade limits as these will dictate how the grades interface with the modifier. Also take a look at your 3d display settings, does the modifier apply to the proposed? A place to start, let me know how you make out. Quote Link to comment
