slate/pavers
shasta
The Arch Tiles is a library file in Object Libraries if you have VW ARchitect.
You use those tile symbols in conjunction wtih the Tile command to fill a 2d polygon with that symbol. It's similar to that of a hatch, but it is not limited to lines.
VW 10 allows you to fill 2d objects with images.
If you are using Vw 10 and have RW, you should have a textures folder. Add this to your Resouce Browser Favorite's List.
SOme of the libray files have images that match the texture themselves. You can then apply the images to the 2d elements in your drawing in the same fashion applying textures to 3d objects works.
You apply the image to the 2d object thru the Attributes palette, fill bucket drop down.
  • 1 year later...
I have been trying for ages to add images as a new resource in documents, but the scale always goes bananas 1 metre bricks don't work! The scale as symbols works but not once I import a jpg. I have tried everything changing resolutions, changing the actual image size - can anyone help?
These include images downloaded for VW
