DomC 242 Posted September 15, 2017 Hi I have nodes, with the following headline: #COMMAND;REFFILE;[VWLibDef]/DomC\Script.py; This is great, because instead of copy/paste an updated code into every node of that type I used in a project it is up-to-date, whenever I edit A node. Also editing a node, will update the resource on my disk and will make up-to-date other nodes which I edit. Also I am able to edit the node in an external editor, whithout copy/paste the result code. Anyone has an Idea, how to update hundreds of nodes in a document, which are all linked to the same file instance but are not up to date. Edit and exit every node after update steals time from making new fantastic marionette projects. Besides: How about tagging the nodes with the year, they are released first time? We have to manually compare (or making a marionette script for resource comparing :-) -> another great Idea) the two versions to see, which nodes are new. How many time I created a custom node, which was already there in a new version but I did not realized. Quote Share this post Link to post
DomC 242 Posted September 21, 2017 Um Have to correct this. Seems like updating the nodes to 2018 deletes (Even if I copy the python Scripts in the library folder) the first line with the #COMMAND;REFFILE; ...... link ... a case for a Bug Report? Either way, Great Version! Particular Multi-View is incredible cool for Marionette Scripters Quote Share this post Link to post
Marissa Farrell 428 Posted September 22, 2017 The removal of the preprocessor when moving files from 2017 to 2018 is intentional because we changed how some of the nodes worked (specifically swapping out input ports for OIP controls) which could introduce broken networks in the newer version. All nodes placed from the Marionette tool in 2018 will still have the preprocessor code. 1 Quote Share this post Link to post
DomC 242 Posted September 22, 2017 Hi Marissa Thanks for quick reply! That's OK. In a special case I used a Beta-Node(Which frequently has to be updated) 100 times in a Drawing (to test different usecases and objects) and used the "Preprocessor" to speed up that process. Maybe for making this, it was a better choice to directly import the code as an external module directly into the node execution next time. Besides, my fairly efficient workflow to edit nodes in the Drawing. It pops up a Script-Edit-Dialoge for every node which matchs to the criteria vs.DSelectAll() criteria = "(('MarionetteNode'.'NodeLocalizedType'='The Node Name'))" def DoIt(h): vs.SetSelect(h) vs.EditObjectSpecial(h, 4)#The edit mode: 0-Default; 2-Properties; 3-Reshape; 4-Edit group like; vs.SetDSelect(h) vs.ForEachObject(DoIt,criteria) Quote Share this post Link to post
the frog 14 Posted September 22, 2017 hello Should I be afraid to switch to 2018 when it's release in France? Some nodes where not changed in the french last sp version. Being, I think, one of the only one using (i try) Marionette in France should I start " flippin' like flag on a pole" or let the good times roll? 1 Quote Share this post Link to post
Marissa Farrell 428 Posted September 22, 2017 @the frog I don't think you should be "afraid" of 2018 I'm not sure how your distributor handles content, but if you find that you don't have the same Marionette content that we have over here, I can help you out and get you the nodes you need from our version. That's the best part about Marionette - it's easy to transfer nodes from computer to computer Quote Share this post Link to post
the frog 14 Posted September 22, 2017 when the 2018 is released I will try my "old" scripts and see how they convert. Then if I have broken network I'll post again Quote Share this post Link to post
Marissa Farrell 428 Posted September 22, 2017 none of your scripts should break moving from 2017 to 2018. Everything will stay the same with them because we will no longer be referencing the external python file that controls the script. You shouldn't see any difference between 2017 and 2018 with regards to that. Quote Share this post Link to post
twk 199 Posted November 5, 2018 hmm this only seems to work for me if I put the py file in a root directory; C:\, D:\, L:\; etc #COMMAND;REFFILE;D:\stair_elevation_maker.py; once i put it in a folder it doesnt work: #COMMAND;REFFILE;D:\test_branch\stair_elevation_maker.py; error pops up saying: - the referenced file not found The specified file was found but could not be written to. Click Ok and made the file writable to save your changee If you choose Cancel you scipt will be saved locally in the node but these changes maybe lost when the scipt editor is opened next time any thoughts on fixes? Quote Share this post Link to post
Lilith Gardell 0 Posted January 4 A happy new year to all of you! Maybe this is the thread my question fits best in. I just opened a vwx2017 file with marionette networks in VWX 2018 for the first time. What is left from the networks is a chaos of pure lines where the connection lines used to be. No nodes at all. The Marionette objects are still there. When I first had a look at the network inside all the connections were cut. The connection lines end somewhere near the other node. When I close and open again. The nodes are magically reconnected. That's not normal, is it? As far as I understand the thread above this should not happen. VWX 2018 doesn't run stable at my computer yet. To be precise: it crushes every time I close it. Even if I don't work in it at all. So I haven't started working with this version seriously yet but stick to VWX 2017. Maybe this marionette conversion behavior gives a clue what is wrong with my VWX 2018 so that could be fixed too? I add both the file in its original vwx2017 version and the vwx2018 version with lines instead of networks. Maybe someone has an idea about this? (About the content: I am trying to produce multiple phyllotaxis with a series of different angles and put them in a row - just wanted to see if DomCs Change Marionette OIP Parameter script, in VWX2018, could help with that. But that's another question.) Phyllotaxis doublizieren und versetzen v2018.vwx Phyllotaxis doublizieren und versetzen.vwx Quote Share this post Link to post
