Saved view: apply to sheet layer viewports
You could open the Organization palette and switch it to Visibilities mode rather than Details, then go to either the Saved Views tab or Viewports tab, select all of the ones you wish to change in the lefthand column (holding shift) and update the visibilities in the other two columns.
It's certainly not a one-click solution, but is a lot faster than altering each one individually.
You can also approach it from a Class or Layer point of view by going to those tabs and choosing which Saved Views and Viewports each is visible in.
  • 3 weeks later...
