In the meantime, here's how to build a Designer + Spotlight workspace.
1. Create a duplicate of the default Designer workspace and name it.
2. Add the Spotlight menus & commands. Here is a compare of the default Designer workspace vs Spotlight workspace. Add the green hightlighted commands on the right side to your workspace (except the Architectural submenu (right side, lines 512-532) which I believe is already included under AEC (left side, lines 445-536).
3. Goto the Tools / Palettes, and add the Dim tools to your Basic toolset. The list of tools to add is in the compare link (right side, lines 918-924).
4. Add a new tool set and name it Spotlight. The list of tools to add is in the compare link (right side, lines 928-963).
5. Add the icon your newly created Spotlight toolset using the attached icon. (This was a quick and dirty screengrab + cleanup until they allow us to select from the builtin icons).
OR, if you want to save a bunch of time, I've attached a workspace file which is just all the above steps completed (no other customizations).
Place the file in C:\Users\YOUR_USERNAME\AppData\Roaming\Nemetschek\Vectorworks\2018\Workspaces
LJ TMS
For future Vectorworks releases, please add the Spotlight menus and toolset to the Designer workspace (or make a seperate Everything Workspace).
Here's a request from 2010
Add the Spotlight Toolset to the Designer Workspace
And 2014
And 2015 (and bumped again in 2017)
VW Designer 2015 - Still no complete workspace with all toolsets
Re-open VW and select it under Tools / Workspaces
Designer+Spotlight_2018.vww
Edited by LJ TMSLink to comment
11 answers to this question
