Followers 0
SamIWas
PIO with text...background color?
4 posts in this topic
I have a PIO that I've created which has some text elements and those text elements must have a background fill to be readable.  My VW preferences are always set to create text without background fill, and unfortunately, this appears to affect PIOs regardless of PIO code.
This is a snippet of the code:
FillPat(1);
FillFore(65535,65535,65535);
FillBack(65535,65535,65535);
PenPat(2);
PenFore(objcolor);
PenBack(objcolor);
TextJust(2);
TextVerticalAlign(3);
TextFont(GetFontID('Avenir Next Bold'));
TextSize(18);
TextOrigin(0,0);
CreateText(concat(distbase,CHR(39)));
No matter what I set FillPat two, it doesn't seem to make the text have a fill color.  I'm not finding something to set the fill color attribute to "solid" without using FillPat.  Am I missing something?
Edited by SamIWas
0
Share on other sites
Sam,
   Have you tried SetFPat()? This will override the document setting for Fill_Pattern.
TextOrigin(0,0);
CreateText(concat(distbase, CHR(39)));
SetFPat(LNewObj, 1);   { sets fill pattern to solid background, which uses the background fill color }
or
SetFPat(LNewObj, 2);   { sets fill pattern to solid foreground, which uses the foreground fill color }
HTH,
Raymond
0
PS - Also try setting the fill colors to something other than WHITE. It may make it easier to spot when it does get applied.
0
Thanks Raymond. SetFPat did work to put white behind he text. It just means adding those lines for every piece of text in the PIO, which is a little annoying. But, the important thing is that it works!
0
Followers 0
