jarjones 5 Posted September 8, 2017 I'm trying to render a bathtub that I've imported from a dwg file. Everything in it is filled, but when it renders, it displays all of the mesh lines. I've done this before and never had this problem, but this one just won't cooperate. Also, is there a way to get smoother renders from imported files? As a scenic designer, I don't want to model every single furniture prop I need to use (especially when exactly what I need already exists online), but I fend that when these render sometimes, they are very chunky looking. Attached is a screenshot of what I get on Final Quality Render. Thanks for any assistance. Quote Share this post Link to post
PVA - Jim 2,390 Posted September 8, 2017 Is Mesh SMoothing enabled for this document (in Document Preferences) or for this mesh specifically in it's OIP? As for the lines, you might be able to get rid of them by editing the mesh, selecting all the 3D polys and setting their Pen attribute to None while leaving their fill, if thats whats showing through. Quote Share this post Link to post
jarjones 5 Posted September 8, 2017 Mesh smoothing enabled: Now it is. I don't think it's technically a mesh at this point, but a group (within a group within a group) of 3d polygons. Should I convert to mesh? When I set the pen to none, the object disappears in wireframe view, unless there's something I'm doing wrong. Quote Share this post Link to post
jarjones 5 Posted September 8, 2017 Never mind. Converting it to mesh did the trick. Thanks for the help! 2 Quote Share this post Link to post
Luis M Ruiz 245 Posted September 11, 2017 When possible, check out how to remake those tubs using nurbs, results are really appealing. 1 Quote Share this post Link to post
jarjones 5 Posted September 11, 2017 Very nice indeed. Is there a way to convert an imported dwg/dxf? The speed of dropping in existing models outweighs the beauty if I have to model them from scratch. Quote Share this post Link to post
Luis M Ruiz 245 Posted September 11, 2017 As you stated before, once objects come in mesh will be the direct translation. Quote Share this post Link to post
