grant_PD
publish script to turn off classes?
I have a client who needs me to publish full sets of plates without any dimensions or notes.  Lucky for me I keep all of my notes in a separate class.  But I'm wondering if there is a script I can use to toggle this global change?  Ideally I'd set up the drawing set, publish in pdf, publish in dwg, run the script to turn off the dims and notes, publish again, run the script to turn back on dims and notes.
It's possible, though I would recommend just duplicating all your sheet layers, as technically your drawing set consists of two full sets of plates.  You may also want to adjust the title block to indicate if this is a sheet that should have notes or not.
To turn off your classes, use the Visibilities mode of the Organization dialog.  You should be able to toggle visibility in all your duplicated viewports at once.
When you Publish, save two sets of sheets, and you can easily toggle between the two in the Publish dialog.
-Josh
If you still want a script...:
Procedure ClassToggle;
CONST
kTestClass = 'NonPlot-Loci';
VAR
  VisStatus : INTEGER;
BEGIN
VisStatus := GetCVis(kTestClass);
IF VisStatus=0 THEN HideClass(kTestClass) ELSE ShowClass(kTestClass);
Layer(GetLName(ActLayer));
END;
RUN(ClassToggle);
(Just change "NonPlot-Loci" to be the Class you're wanting to control.
Edited by C. Andrew Dunning
Actually, not quite so easy if we're talking sheets and viewports.  You have to step through each viewports and run GetVPClassVisibility() /  SetVPClassVisibility() to toggle the class.
Good catch, Josh.
Try this, instead:
Procedure ClassToggle2;
CONST
 kClassON = 0;
 kClassOff = -1;
 kClassGray = 2;
VAR
 DialogVisState : BOOLEAN;
 VisState : INTEGER;
  PROCEDURE ClassSwitch(H:HANDLE);
  BEGIN
   IF SetVPClassVisibility(H,kTestClass,VisState) THEN BEGIN END;
  END;
BEGIN
 DialogVisState := YNDialog(Concat('Do you want the Class "',kTestClass,'" visible?'));
 IF DialogVisState THEN VisState := kClassON
   ELSE
  VisState := kClassOff;
 ForEachObject(ClassSwitch,(ST=REGVIEWPORT));
END;
RUN(ClassToggle2);
CONST
VAR
BEGIN
END;
RUN(ClassToggle);
Thanks for this. How do you add a Design Layer as well? So you can toggle a design layer + class.
On 11/2/2018 at 7:20 PM, C. Andrew Dunning said:
Christiaan -
It is the same syntax, except for using "GetLVis," "HideLayer," and "ShowLayer."
Make sense?
I tried this but I'm getting at error (have no idea what I'm doing!):
CONST
kTestClass = 'NonPlot-Brick grid';
VAR
BEGIN
END;
RUN(ClassToggle);
Procedure LayerToggle;
CONST
kTestLayer = 'BRICK GRID';
VAR
BEGIN
VisStatus := GetLVis(kTestLayer);
IF VisStatus=0 THEN HideLayer(kTestLayer) ELSE ShowLayer(kTestLayer);
END;
RUN(LayerToggle);
Try this, instead:
CONST
VAR
  ActLayerName : STRING;
BEGIN
ActLayerName := GetLName(ActLayer);
VisStatus := GetLVis(GetLayerByName(kTestLayer));
Layer(kTestLayer);
IF VisStatus=0 THEN HideLayer ELSE ShowLayer;
Layer(ActLayerName);
END;
RUN(LayerToggle);
Thanks C, how do I include the layer ("BRICK GRID") and the class ("NonPlot-Brick grid") in the same script?
Edited by Christiaan
Try this:
Procedure LayerClassToggle;
CONST
 kClass = 'NonPlot-Brick grid';
 kLayer = 'BRICK GRID';
 kON = 0;
 kOff = -1;
VAR
 LayerVisStatus,ClassVisStatus : INTEGER;
BEGIN
 LayerVisStatus := GetLVis(GetLayerByName(kLayer));
 Layer(kLayer);
 IF LayerVisStatus=0 THEN HideLayer ELSE ShowLayer;
 ClassVisStatus := GetCVis(kClass);
 IF ClassVisStatus = 0 THEN HideClass(kClass) ELSE ShowClass(kClass);
 END;
RUN(LayerClassToggle);
Any idea how to make sure they're synced when the toggle is activated? As it stands if the layer is off and the class is on, it will simply swap this around to layer on, class off.
The logic I'm after is:
1. If either layer or class is off, then toggle both layer and class on
2. If both layer and class is on, then toggle them both off
Here's what might be a better approach:
CONST
VAR
 ClassLayerVisible   : BOOLEAN;
BEGIN
 ClassLayerVisible := YNDialog(Concat('Do you want the Class "',kClass,'" and the Layer "',kLayer,'" visible?'));
 IF ClassLayerVisible THEN
  BEGIN
   Layer(kLayer);
   ShowLayer;
   ShowClass(kClass);
  END
    ELSE
   BEGIN
    Layer(kLayer);
    HideLayer;
    HideClass(kClass);
   END;
END;
That pop-up by-passes testing which is visible or invisible (Class or Layer) and simply makes them both the state you choose.  That way, VW doesn't have to read your mind...  ;-)
But it doesn't need to read my mind, it only needs to test for the following:
