Darren K Posted September 1, 2017 Share Posted September 1, 2017 Hi folks, I am creating some hidden line viewports, and my dimension lines are not showing up. The text box is still there, but the lines are gone. Class/Layer visibility is ok. I tried at first doing a background wireframe and a foreground hidden line, then just a background hidden line. They will show up when I initially go to the sheet layer, but once the viewport is updated, they disappear. If I use Open GL they are there, but that isn't what I want to send out. All dims are set to Layer plane. I've also done a full restart of the program, just in case. Any help would be greatly appreciated! I am running Spotlight 2017 SP4 on a mid-2015 macbook pro 15" (El Capitan 10.11.6). Darren Dimensions.pdf Quote Link to comment
markdd Posted September 1, 2017 Share Posted September 1, 2017 I have no problems seeing dimensions in Hidden line with in a sheet layer viewport.Are your dimensions on a design layer? If so, are you sure that there is no 3d geometry accidentally covering up what's missing. It's a really easy mistake to make. Quote Link to comment
Darren K Posted September 1, 2017 Author Share Posted September 1, 2017 You may be onto something there, I moved all of the lines 1" off the ground and now they appear. I do have a rectangle "stage" that could have been covering them, although I purposely put that at the bottom of the layer stack. It also changes the plane to 3D from Layer, but I don't know if that matters. Thanks! Quote Link to comment
Kevin McAllister Posted September 2, 2017 Share Posted September 2, 2017 I would recommend dimensioning in the annotations space of your sheet layer viewport rather than in the design layers. You'll keep your model clutter free, they'll always render properly and they'll always be "on top". Kevin 1 Quote Link to comment
Darren K Posted September 3, 2017 Author Share Posted September 3, 2017 Not a bad idea at all. I will give that a try. Thanks! Quote Link to comment
Chris Clymer Posted January 30, 2023 Share Posted January 30, 2023 Hi Folks, Just ran into a similar issue as Darren K. I was placing dimensions in Annotation Viewport on a sheet layer and my dimension text was visible, but lines were not. In the OIP, all class settings were correct, and I was placing dimensions within the correct class. The issue for me turned out to be that "Class Style" under "Pen" in the Attributes tool pallet at bottom left was set to "None". Changing the Pen to "Class Style" made dimension lines appear. Hope this is helpful for someone else. Quote Link to comment
