Cadplan Architecture
Shiiping container model wanted
Here is a container from sketchup .skp (cleaned up and ready to go). It can be used in VW2015 onwards
Works fine in VW (I can't put it in there as I am an education user and you would get a watermark).
Import as sketchup, make sure you have create renderworks textures for all materials. The resulting import will be a symbol which can be resized as required. You can delete Layer_Layer0 material and changes the others to suit.
shipping container.skp
Edited by barkest
On 31/08/2017 at 0:06 AM, Taproot said:
Here's a standard 20' and a 40' high cube.
These are realistic in the sense that the surfaces are corrugated.  If you are planning to modify the units, I've found subtracting / adding solids to be the easiest workflow.
Cargo Containers 20 & 40 High Cube.vwx
That's great, one slight problem is that it won't open in VW2016, Do you have it it 2012 onwards? cheers
thanks I might give it a go if the VW file method proves troublesome although I don't have Sketchup
You don't need Sketchup. Just import directly into VW. You can scale and retexture inside VW as well. It is all good to use
He has VW 2016 and the SKP file is a too new version so he needs Sketchup
to convert to previous SKP version or a VW 2016 import (?)
Barkest may have already met your need, but sure ... here's a 2012 version of the file:
Cargo_Containers_20_&_40_v2012.vwx
@trashcan There are shipping containers in the Resource Manager in the Objects-Landscape Site>Equipment Shipping Containers file.  There are multiple sizes and they can be connected together to make different structures.
