Nodes Excluded when Network Wrapped
When you wrap the script the 2 rotation nodes are left behind but in fact if you change the rotation parameter in the OIP it works normally. Now once the script is wrapped, if you delete the nodes it still works. Willofmaine have invented the ghost nodes!
In my case (French version) that’s what I get. What about you with your version?
To answer your question yes when moving the 2 nodes it wraps ok
 moving only the top one no changes
moving the bottom one wraps ok
