export to artlantis - bits missing
Caroline,
Some ideas;
If the "missing items" are symbols or nurb items, you need to convert them to different format.
Make sure you assigned the items a fill color and that the item is filled in the attributes pallete.
You can also try "export all colors" in the Artlantis export dialogue box.
If you were updating an Artlantis files, make sure that file is closed in Artlantis. An open file doesn't update.
Hope above helps.
