Wesley Burrows
Camera Viewport Fullscreen Help
This is probably a stupid question.  But sometimes (seemingly randomly) when I double click a camera on top/plan view I get the attached,   rather than the full screen view from the camera,  When it happens it seems as though all the cameras do it,   what on earth am I missing?  When I add a new camera it also looks like this,  which leads me to believe I inadvertently switched some view setting with a keyboard shortcut.  Thanks!
-Wes
Edited by Wes Burrows
On the first tab of Document Preferences there should be a checkbox called "Cropped Perspective" which causes this. Note that since it's a document setting, if you change the setting in one file it won't affect other files. If you always want it on or off, make sure to change the setting in your template file.
My problem is that "cropped perspective"
which I never ever want,
since VW 2017 very often activates itself.
Ha looking from a camera view is the only time I would ever want "cropped perspective". It should be linked to the camera object so I can accurately compose a camera view the first time.
Kevin
Kevin
I'm crossing my fingers that this and other camera-related issues might be addressed in 2018. So many people use cameras and they could be soooooo much better.
Kevin
Oh also - for this very reason I mapped Pat's awesome Perspective Crop Toggle script to one of the buttons on my 3Dconnexion mouse. It works like a charm and lets me effortlessly switch back and forth.
I want full screen when designing/modeling, and cropped when setting up camera views.
Now this would have made a great teaser Tuesday!
KM
I even don't want that.
(BTW outside of VW there exist far better examples on how to control cameras)
For me the crop is always in any arbitrary thumbnail size.
And when clicking in blank space to deselect anything, in the past I could
at least "fit view" the crop. In VW 2017 it will always destroy my camera
perspective.
Together with the buggy behavior of de/activating cameras, I have a bunch
of them destroyed in seconds.
Even linked in VPs they tend destroy their data arbitrarily when I try to do changes
in camera mode. For me cameras are completely unusable - which is quite pity
because being large part of my job.
But I stopped crying about buggy camera system years ago.
There are currently far worse things existentially annoying me.
Edited by zoomer
My only other experience with cameras is in C4D where they are much more intuitive. I only use the crop for composing a view and for seeing the aspect ratio. Ideally when you edit a camera it would fill the editor viewport frame and indicate via shading the safe (rendered) area within the camera.
I've had a lot of problems with duplicating viewports with cameras. My workflow involves duplicating a lot of viewports for speed but camera viewports won't let go of their original settings and get broken easily.
In general, I use cameras to view the model in perspective. I wish I could work in perspective but until the 3d view is unlinked philosophically from the orthographic views in Vectorworks its impossible. Since I shift back and forth between views a lot while working I don't want to reset to Top/Plan between every view change and then reactivate perspective each time I shift into 3d. I need my orthographic views to be flat projections.
Kevin
My experience has been the same.  It seems to activate itself.   I can find rhyme or reason to it.
UPDATE:
It seems as though if I'm looking through camera with "Cropped Perspective" deactivated,  I quickly try to change views without thinking,   say hitting #6 on my numpad (instead of going to a top/plan view first),  and realizing what I did hit cmd+z to undo it.   After you undo your view change it seems to auto-activate.    Is this a bug or the intended behavior?   I don't recall it doing this in 2016.
Updated my findings.
cropped perspective
arbitrarily activates itself for me even without any cameras
(which I gave up as I said)
just by switching my Iso temporarily from my default orthogonal
to one of the perspective options.
Yes, I have one project where I use duplicated VP with hidden camera
for different versions.
But cameras went corrupt also before duplication.
