convert to polygon doesn't work in marionette object
  • Marionette Maven
I found the problem, and it is within the Convert to Polygon node.
For some reason, we're setting the planar reference again and then trying to move it, which I believe in most cases is unnecessary, though I'm sure it was included for a reason, it just seems to not work when in a Marionette Object's coordinate space. (Likely because in a Marionette Object, planar objects default to screen plane, and we try to move it's location in the Z direction which does not exist in screen plane, whereas when you run a Marionette Network on your drawing area, all objects are drawn to the layer plane.)
I'll see if I can insert some logic in there to remedy this.
Thanks for pointing it out!
