Tilt a television object backwards (so it is angled facing up)
Hi
I am sure I have done this before, but can't seem to now.  I have a 24" Television object (from Spotlight) and want to show it mounted in a plinth, leaning back at an angle.
I go to a side view,
Select the television, then the rotate tool,
When I try and rotate it :
In screen plane - nothing happens
In screen aligned,  I get the message "Hybrid objects can only be rotated in a plane parallel to the active layer plane.  Would you like the working plane set to the active layer plane?"  (Yes or no).  Neither option helps.
What am I missing?!
Thanks,
Andrew
Hybrid 2d/3D objects cannot be rotated about the X or Y axis. The 2D portion constrains that. If you want to rotate the TV set back (along the X or Y axis) then either remove he 2D portion or rotate the 3D portion inside the symbol definition.
You will find this constraint on all Hybrid symbols. Spotlight symbols confuse this issue because they will rotate the 3d portion, but that is because the symbol has been converted to a plug-in object and the 3D portions have parts records attached..
Hope that helps
Mark
Edited by markdd
  • 7 years later...
Hi Andrew & Mark,
I too am having issues tilting a plug in tv object in Spotlight.
I've tried following the steps and suggestions the both of you have commented on but nothing seems to be making sense.
- I pull a correct size tv from the Television Tool.
- Aligning the working plane doesn't allow to lock a new angle
- I don't see anything 2D to remove when editing 2D components
- Converting to a symbol still restrains any tilt ability because the hybrid element is still baked into the object.
What am I missing?
