Vectorscript to Increment record data
I'm trying to write a script that will update the P_Revision Number field on my custom title block + 1 of the current value.   I have the below,  but everytime I try to read the record it only returns 0.   The default value of the revision field is 1.
Procedure Update_Rev;
VAR
	current_rev :INTEGER;
	new_rev :INTEGER;
	hd: HANDLE;
Begin
	current_rev:=Str2Num(GetRField(hd,'Vista Title Block','P_Revision Number'));
	new_rev:=current_rev + 1;
	SetRField(FSActLayer,'Vista Title Block','P_Revision Number',Num2Str(0,new_rev));
End;
Run(Update_Rev);
What am I missing?
Record format for Title Block attached.
Edited by Wes Burrows
spelling and clarification.
Ok, well i fixed it by changing the GetRField Handle to FsActLayer.     Now I just need to figure out how to get the script to select anything with the title block  "Vista Title Block" record.  So I don't have to select the sheet border or anything for it to work.   I also want to get it to update it across all sheets.   Even though I'm updating "P_Revision Number"  It only updates on the currently selected sheet.  Thoughts?
VAR
	new_rev :INTEGER;
	hd: HANDLE;
Begin
	current_rev:=Str2Num(GetRField(FSActLayer,'Vista Title Block','P_Revision Number'));
End;
Run(Update_Rev);
spelling
