zack310 Posted August 17, 2017 Share Posted August 17, 2017 Hi All, was wondering if anybody has had any issues similar to what I'm having. I've got symbols which have text boxes in Layer Plane as part of the symbol, which look fine in my design layer in any rendering style. However, when rendered in a viewport on a sheet layer the text box if off center and half of it is missing. This happened no matter what scale the viewport was in. Let me know if anybody has any ideas, thanks. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted August 17, 2017 Vectorworks, Inc Employee Share Posted August 17, 2017 Does the same issue happen with any font? Quote Link to comment
zack310 Posted August 17, 2017 Author Share Posted August 17, 2017 30 minutes ago, JimW said: Does the same issue happen with any font? It sure does, I hadn't thought of that but I've just tried that. Quote Link to comment
zack310 Posted August 17, 2017 Author Share Posted August 17, 2017 Here's a screenshot of what i mean, you can see the text box has been shifted off-center but in the symbol in the design layer it is perfectly centred. Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted August 17, 2017 Vectorworks, Inc Employee Share Posted August 17, 2017 The fastest way to get around that will be using Text > Convert Text to Polyline, and then extruding that text so that it is a real 3D object, then you'll have full control over it. I have seen a lot of issues related to simple text objects not functioning when placed in a 3D environment. OpenGL seems to handle this better but I have seen it fail there as well. Quote Link to comment
zack310 Posted August 17, 2017 Author Share Posted August 17, 2017 2 minutes ago, JimW said: The fastest way to get around that will be using Text > Convert Text to Polyline, and then extruding that text so that it is a real 3D object, then you'll have full control over it. I have seen a lot of issues related to simple text objects not functioning when placed in a 3D environment. OpenGL seems to handle this better but I have seen it fail there as well. Thanks! That makes a lot of sense, I'm sure that will work I'll give it a try! Quote Link to comment
