Andy Broomell Posted August 15, 2017 Share Posted August 15, 2017 How do I make Hidden Line (and Section Viewports, in the end) display the lines between separate Wall objects? Wireframe: Hidden Line: I'd like to be able to see the three discrete walls since this is being built in three pieces. AutoJoin is turned off, so they're not joined. I'd also prefer to not nudge them apart at all. Any solution? Quote Link to comment
Pat Stanford Posted August 15, 2017 Share Posted August 15, 2017 I think you could either zoom in and nudge them just a fraction. or possibly resize them so they are a very small amount (say 0.1mm, 1/32") smaller. In Top/Plan you could do the offset so they are ever so slightly not in the same plane. Not what you wanted to hear, but my best suggestion. Quote Link to comment
bcd Posted August 15, 2017 Share Posted August 15, 2017 An interesting dilemma. Short of going back to 2012 where these lines showing in HLR was a constant problem can you explain why you need to show them as separate walls. Perhaps therein lies the solution? Or render with Polygon Shaded. Quote Link to comment
twk Posted August 15, 2017 Share Posted August 15, 2017 2 minutes ago, bcd said: render with Polygon Shaded. I was going to suggest this ^ Quote Link to comment
