autumnsnow Posted August 15, 2017 Share Posted August 15, 2017 Hi all, new to this forum, lots more to learn, but thank you all for being here. I've been having this problem that I can't work around and it's causing much frustration. After adding a co-worker's referenced file, I have disappearing design layers when I toggle between the layers. When my own design layer is active I do not see any of the referenced design layers. It is only when I set the referenced design layer to be active then I can see that particular layer. Visibilities are set to all visible. The only toggling I'm doing is on the active layer section. Any pointers for this or am I just missing something? Thanks all! Quote Link to comment
markdd Posted August 15, 2017 Share Posted August 15, 2017 If all Layer and Class visibilities are set to Show Others then you might want to switch your Navigation Graphics performance in the Display options of VW preferences to say Good Performance and Compatibility. I have found that a number of visibility issues have been resolved by toggling this setting. Quote Link to comment
Hans-Olav Posted August 15, 2017 Share Posted August 15, 2017 Maybe the layers are in different scale? Go to Layers, chose scale, and set All Layers to preferred scale. Hope this helps Quote Link to comment
autumnsnow Posted August 15, 2017 Author Share Posted August 15, 2017 Thanks Hans that totally worked!!! oh man things I didn't think about. Thanks markdd for the tip too, will do that when I face weird problems next time. Loving this forum! Quote Link to comment
Andy Broomell Posted August 15, 2017 Share Posted August 15, 2017 (edited) If you're ever in a situation where you need the layers to be at different scales, just turn off "Unified View" under the View menu (or go to Unified View Options and uncheck "Ignore layers with different scale"). Edited December 14, 2017 by Andy Broomell 1 Quote Link to comment
