Cadplan Architecture Posted August 14, 2017 Share Posted August 14, 2017 Is there a shortcut for toggling between 0º, 90º, 180º, & 270º with the plan rotated? Quote Link to comment
Vectorworks, Inc Employee PVA - Admin Posted August 14, 2017 Vectorworks, Inc Employee Share Posted August 14, 2017 You can map the Rotate Plan command itself to a keyboard shortcut via the Menus tab of the workspace editor. But I do not think it's possible to map specific angles, it seems that the command assumes either graphical input via the widget or numeric input in the View bar. 1 Quote Link to comment
Cadplan Architecture Posted August 14, 2017 Author Share Posted August 14, 2017 Thanks Jim, sounds like I might as well stick to enering manually! Quote Link to comment
bcd Posted August 14, 2017 Share Posted August 14, 2017 (edited) You can create a Saved View with only the Plan Rotation (Orientation)- then a double click in the SV palette will get you there quickly. Edited August 14, 2017 by bcd 3 Quote Link to comment
Cadplan Architecture Posted August 14, 2017 Author Share Posted August 14, 2017 cool that's a great workaround, many thanks! Quote Link to comment
PeterT Posted August 22, 2017 Share Posted August 22, 2017 Also, Command 5 (Top/Plan) will restore the view to 0° from whatever angle you are displaying. Quote Link to comment
