TArchit Posted August 3, 2017 Share Posted August 3, 2017 Some window tags are not showing correctly in our section viewport elevations. They appear backwards and also through walls, as attached. Does anyone know why this is happening and how to rectify it? Thanks Quote Link to comment
AlanW Posted August 3, 2017 Share Posted August 3, 2017 (edited) @TArchitTry ticking this box to see it it helps. Also if your walls class is not set to solid you will get it transparent and see windows on other side. Cant seem to get text to flip. Edited August 3, 2017 by Alan Woodwell Quote Link to comment
TArchit Posted August 3, 2017 Author Share Posted August 3, 2017 Thanks @Alan Woodwell. Unfortunately that box was already ticked and when I unticked it there didn't seem to be any change. The windows are on solid classes as when. Aside from the reversed text the issue is mainly with tags showing through walls as opposed to walls showing through windows. Quote Link to comment
Guest Wes Gardner Posted August 3, 2017 Share Posted August 3, 2017 Can you tell us what version of the software you are using? This has been a known issue in the past. You may want to put the version, etc. in your signature. Quote Link to comment
