danbates Posted July 28, 2017 Share Posted July 28, 2017 ...AND MUST KNOW WHAT CLASS I'M DRAWING IN ALL THE TIME.. All good I would like a clearer indication of what class is active as I draw. I sometimes get a few lines down the line and have to spend time correcting my own forgetfullness. Any tips? 1 Quote Link to comment
bcd Posted July 28, 2017 Share Posted July 28, 2017 I often glance North West to see what the active class is - Quote Link to comment
danbates Posted July 28, 2017 Author Share Posted July 28, 2017 Seriously considering getting a magnifying glass I can attach to my massive monitor. Quote Link to comment
markdd Posted July 28, 2017 Share Posted July 28, 2017 Layers is easy - by changing the Interactive appearance settings in preferences. There is no setting for classes though. Might be a good Wishlist item? Quote Link to comment
bcd Posted July 28, 2017 Share Posted July 28, 2017 (edited) I use the opt-Scroll to zoom the screen, a feature of Apple's Magic Mouse2 , about 1000 times a day Edited July 28, 2017 by bcd Quote Link to comment
danbates Posted July 28, 2017 Author Share Posted July 28, 2017 1 minute ago, bcd said: I use the opt-Scool feature of Apple's Magic Mouse2 about 1000 times a day opt-Scool?! The specs look good. However did just find these: https://www.harrisoncameras.co.uk/pd/Night-Owl-NOBG1-Tactical-Night-Vision-Binoculars_490318?gclid=Cj0KCQjwwevLBRCGARIsAKnAJveic5Sn-klP1TzlE2ylW1Q8nUdaQhauMMO5zyE-S1XqFUGn3-irtd4aAqJmEALw_wcB For draughting at night. Quote Link to comment
MullinRJ Posted July 28, 2017 Share Posted July 28, 2017 7 hours ago, danbates said: opt-Scool?! In the Mac's System Prefs > Accessibility > Zoom, check the "Use scroll gesture with modifier keys to zoom:" checkbox and choose one of the 3 modifier keys. When you hold that key down and roll the mouse wheel your screen will zoom about the cursor. I use the the Control Key, since VW uses the Option Key on the Mac for almost everything. This is a HUGE saver on aging eyesight and a lot cheaper than those fancy goggles. 8-) Raymond 1 Quote Link to comment
zoomer Posted July 28, 2017 Share Posted July 28, 2017 (edited) Funny, I never look north west. I either look south east in navigation palette if accidentally in class mode or mostly north east in OIP after I draw something, to check which class was active Caring about classes is oldschool. Classes should be auto selected and changed by VW, like it works by PIOs. Edited July 31, 2017 by zoomer 1 Quote Link to comment
Benson Shaw Posted July 29, 2017 Share Posted July 29, 2017 I've recently noticed that the Eye Dropper tool has a pref that changes the active class of the drawing to the class of the "picked" object. That pref has probably been there for ever, but is this intentional? I thought the intent would be to pick (eye dropper) attributes, including class, from a source object, then use the Put (bucket ) mode to change the class (and other attributes) of a target object or selection, and only of the target object (or selection). But this action also changes the active class of the whole drawing to the class of the source object. Really messed me up several times! -B 1 Quote Link to comment
Andy Broomell Posted July 29, 2017 Share Posted July 29, 2017 @Benson Shaw It's not the Class parameter that's specifically doing that, but rather the "Pick Up Sets Defaults" checkbox. And it's affecting more than just the active Class: it can also, for example, change the active pen and fill colors to match the object you sample from, allowing you to draw more objects with the same attributes. Or you can "pick up" a font from a text box to make it your active font with which future objects are created. Etc. If you uncheck "Pick Up Sets Defaults" you should find that your Active Class doesn't change when using the Eyedropper. 1 Quote Link to comment
bcd Posted July 29, 2017 Share Posted July 29, 2017 14 hours ago, zoomer said: Caring about classes is oldschool. Classes should be auto selected and changed by VW, Yes, as much as is possible, PIOs and symbols do it, but often when using tools to draw primitive objects VW has no way of interpreting your intention. eg - is my Polygon a profile for an extrude, a sightline study or a driveway kerbline? Will it become a path object in an EAP or remain on final drawing documents? We used to have the Task Manager to handle this pre-decision and class activation but it was retired to the VW tools & tricks museum Paying attention to classing is very much now-school in my world, however it's done: I notice a lot of folks use scripts to set the task but you're right VW should handle it, perhaps the wish is a graphical task manager palette that's merges the script palette customization that people use with the look & layout of the Organization dialog and the Resource Selector Quote Link to comment
zoomer Posted July 29, 2017 Share Posted July 29, 2017 Yes, I was exaggerating I also care about my Classes. Quote Link to comment
danbates Posted July 29, 2017 Author Share Posted July 29, 2017 I would love VW to read my mind also. Quote Link to comment
Benson Shaw Posted July 29, 2017 Share Posted July 29, 2017 @Andy BroomellOK, yes, sort of. Never ran into this until recently. My Pick Up Sets Defaults must have been enabled unwittingly. Also, the Pick Up Sets Defaults requires some conditions not stated in the manual. This from VWX help: Pick Up Sets Defaults Changes the default Attributes palette settings to match those of the source object; objects created from then on use the attributes of the source object Testing shows that this functionality only applies to the attributes palette items with By Class. Otherwise, the source object attributes are not transferred to the attributes palette. Source object needs to be By Class, too, I think. Apparently, some combo conditions of drawing settings, source object settings and Eyedropper prefs produce different results from the Help statement. Anyway, thanks Andy, for pointing out this pref! Learning every day! -B Quote Link to comment
Rossford Posted July 30, 2017 Share Posted July 30, 2017 Wonder if class/layer could be added on the bottom line to give you one more place to look? Or, perhaps be in a small pop up box when you activate a tool? Quote Link to comment
danbates Posted August 22, 2017 Author Share Posted August 22, 2017 I'm not sure if this is the solution. 2 Quote Link to comment
Gadzooks Posted August 22, 2017 Share Posted August 22, 2017 Good one. That rendering is almost life-like. To put rain on the window glass must have been a pain. I like the cluttered office look with boxes and paperwork. Looks just like mine. (BTW - I think I spot a cold bridge on the parapet detail.) Quote Link to comment
danbates Posted August 22, 2017 Author Share Posted August 22, 2017 It's actually real Yorkshire weather out there. Upstand of insulation? Course of Foamglas? Oh the options. Quote Link to comment
