RickR Posted July 27, 2017 Share Posted July 27, 2017 So how can I reverse the stacking order of a large number of objects. My current project has 74 pages imported from PDF. A wish list item for importing a PDF that way, and waiting x years, is not the best answer. Anybody got a neat trick? Quote Link to comment
Pat Stanford Posted July 27, 2017 Share Posted July 27, 2017 Try this script. Procedure Reverse_Stack_Order; {© 2017 Pat Stanford pat@coviana.com} {Licenced under the LGPL} {Reverses the stacking order of selected objects} {Brings all selected objects to the top of the stacking order} {No Warranty Expressed or Implied. Test for suitability} {before use on live data. Make backup copies.} {Avoid caffine and alcohol when using.} {Excessive amounts of carrots may be bad for your health.} Var H1,H2,H3 :Handle; N1,N2: Integer; Begin; H1:=FSActLayer; H2:=LSActLayer; H3:=H1; If Count(((VSEL))) >1 then Begin Repeat Begin H3:=PrevSObj(H2); HMoveForward(H2,True); H2:=H3; End; Until H2=H1; HMoveForward(H1,True); End; End; Run(Reverse_Stack_Order); 1 Quote Link to comment
RickR Posted July 27, 2017 Author Share Posted July 27, 2017 Wonderful, that is just what I wanted and definitely a keeper. Thank you! Quote Link to comment
