Moving a linear array
RickR
I'm back to my traveler curtain object.
My current issue is a symbol that is arrayed. When I apply a move command to the resulting group, the source symbol moves, but all it's copies don't. There seems to be something wrong with the 'Linear Array' node, I think came from @DomC  What would folks suggest for an alternate method?
More in the "why did it do that" category: There are 2 Soft Goods objects that get made into groups, that I can't seem to ungroup.
Hi Rick
There is nothing wrong with the "Linear Array xyz"- Node. It moves the object you input and returns them as single objects (The group is made from Marionette after all object creation). If you connect a "Move"-Node, it will move every object by your move Vector.
The "Linear Array xyz" - Node, will do the  job.
Node:
The Move-Node is not error free. If you have a screen planed symbol it will not move. If you have this, just use this "corrected" Move-Node
Move corrected.vwx
Anyway: It would be better (faster) to just move your first object on the right place, and then array it. If you move them after array you move them a second time.
Edited by DomC
But Rick is not using the Linear Array xyz node, but instead the Linear Array node.
When you wire that to a Move node, it does not move each object, but only the last object in the array.
My Python is not very good, but it looks to me like the data coming back out of the node in the self.Params.array.value = objs line is being over written with each iteration through the loop meaning there is only a single value moving on the the Move node.
I am probably wrong, but if not, can you explain how that line works to provide the proper array return?
You got it pat ;)
I could solve it by replacing the += with .append:
def RunNode(self):
	dir = self.Params.dir.value
	obj = self.Params.obj.value
	a = 0
	b = self.Params.step.value
	c = self.Params.count.value
	list = []
	if c != 0:
		list = [a+n*b for n in range(c)]
	objs = []
	for i in range(len(list)):
		if dir == 0:
			objs.append (vs.HDuplicate(obj, list[i], 0)) # Changed += to append
		elif dir == 1:
			objs.append (vs.HDuplicate(obj, 0, list[i])) #  Changed += to append
The node creates 5 duplicates so you get 6 object s in total at the end. The original was not passed out the Linear Array node.
I appended a Delete-node to the Line-node, maybe you want to at it rather to the output list of linear array.
597845bdebbf8_Bildschirmfoto2017-07-26um09_29_58.png.f588489eca6dee84ab50c2329ce0c9f7.png
regards
Edited by Patrick Winkler
I'll leave the Python wrestling to you guys.
"Linear Array XYZ" is doing the job. In my network I was moving many things at once, so it is more efficient programming and I suspect faster in the long run.
Thanks Pat for reminding me to delete the original object. I think that caused some issues earlier, but never again. (maybe)
I think I've found another odd ball, but I'll post fresh.
