reinierbij
No texture with DWG export
Hi,
For my company I drew models of the Danley sound labs speakers. I want to share those with my colleague who doesn't has VW. I read on this forum that the best way to do it was using a .DWG format file. When I export The models there is no problem. I wanted to check of the export was succesful, so I imported the model and it turnt out as a complet white model. I tried to edit the colors and textures of the classes but i kept comming out completly white. Does someone now what I am doing wrong? I also exported it to 3DS. Here the problem didn't accure.
If you want more information on what I use just ask:)
Share this post
Link to post
Textures are not exported when you Export to DWG from Vw; see this page from the Vw 2017 Help File.
If you want to export with textures, use 3DS as you have already discovered.
Edited by rDesign
Share this post
Link to post
