  • 4
michaelk
Class order in Nav Palette different from Command Right/Left Arrow
Pretty sure this is a bug.
I'm seeing the class names sort by alpha then numeric in the nav pallet, but when using Command-RIght Arrow and Command-Left Arrow the class names sort only alphabetically.
For example:  In the nav palette the classes look like
Class-1
Class-2
Class-3
Class-101
Like you would expect.
But when Class-1 is active and you hit Command-Right Arrow the order is
Class-1 > Class-10 > Class-100 > Class-101 > Class-11 > Class-12 …
If this is working as expected, I'd like to request that the Command-Right/Left Arrow order be made the be the same as the order in the Nav Palette.
4 answers to this question
Not sure if you are really using those numbers, but 1 could be 01, followed by 02, 03, etc. before hitting 10.
For example, I name all my drainage pipe classes with a D prefix, as in, D-04 pipe, D-06, D-08, D-10, D-12, etc. The D keeps them in some sort of order I expect (not sure where a number first class might show up) and the "0" before the 4 and 6 inch pipe keeps those classes in numeric order, as I want to see them.
Edited by Rossford
Absolutely.  That's the workaround.
But I would like the order that it appears in the Nav Palette to be the order that the keyboard shortcut cycles through.
