Drawing threaded rods
Bruce Kieffer
4 answers to this question
39 minutes ago, Pat Stanford said:
Try the Shaft 3d tool from the Machine Components tool set. You might have to go back into the settings after you place the object and turn on the threads, but I think you can make it give you a threaded rod of whatever diameter and length you want/need.
Thanks Pat. That works. It is a bit goofy to get the configuration set, and the threaded rod created really bogs down my computer. I will try making it a symbol. I will also try Marissa Farrell's Marionette object.
