NickS Posted July 17, 2017 Share Posted July 17, 2017 Hi guys, Wondering if anyone out there can help me try to figure out how to duplicate symbol(s) along a path using Marionettes? Self-admittedly relatively new to marionette, but have a programming background (never tried VectorScript, mostly due to no available time). I see there is a Operations-->Duplicate node however no Duplicate-along-path node. What I am trying to achieve is something akin to the Railing/Fence tool in Landmark, but with an ability to space balustrade symbols we have already created along the path (and hopefully in future iterations draw in posts and rails too). The purpose of this is to save my designers time having to 3D the missing rails and posts while still being able to count the number of balustrade symbols in a worksheet for quantifying. Currently, the tutorials I have viewed seem to be that the network runs and then you adjust variables to suit (e.g. polyline co-ordinates), rather than being able to free draw a polyline and have the network use the polyline as the basis of the duplicate-along-path (i'm sure my inexperience and impatience is going to land me in hot water with some of you!), again akin to the Railing/Fence tool Would love to then extend this functionality into drawing retaining walls in, specifying the correct(ish) height, and quantify the required length of retaining boards (and hopefully posts too) by classifying the extrudes and dividing the volume by the respective cross-sectional areas. Any and all help appreciated Quote Link to comment
AlanW Posted July 17, 2017 Share Posted July 17, 2017 (edited) Hi have a look at the videos on my YouTube channel Alan Woodwell. Also search my journey through marionette by Louis ruse he has some great introductory ones Edited July 17, 2017 by Alan Woodwell Quote Link to comment
Marionette Maven Marissa Farrell Posted July 17, 2017 Marionette Maven Share Posted July 17, 2017 @NickSHere's the simplest script that shows how to place a symbol along a curve at equally spaced intervals, to get you started. The important thing is to ensure that your path is a NURBS curve. I'd be more than happy to give you further direction if you need it dupSymAlongPath.vwx Quote Link to comment
NickS Posted July 17, 2017 Author Share Posted July 17, 2017 10 hours ago, Alan Woodwell said: Hi have a look at the videos on my YouTube channel Alan Woodwell. Also search my journey through marionette by Louis ruse he has some great introductory ones H Alan, I have done a bit of youtube stalking :-) In fact, it was your extrude symbol along path that made me think about it in the first place. Thanks Quote Link to comment
NickS Posted July 17, 2017 Author Share Posted July 17, 2017 5 hours ago, Marissa Farrell said: @NickSHere's the simplest script that shows how to place a symbol along a curve at equally spaced intervals, to get you started. The important thing is to ensure that your path is a NURBS curve. I'd be more than happy to give you further direction if you need it dupSymAlongPath.vwx @Marissa FarrellThanks for that, will take a look this afternoon/evening! Quote Link to comment
AlanW Posted July 17, 2017 Share Posted July 17, 2017 (edited) @NickSHere is a network that i created for a fence. You can change parts from circle to poly, set element sizes and spacing etc. This hopefully will help in understanding the process. HTH I will have a look at bringing this into a spreadsheet to do a materials take off. Fence_Sq_or_Circ_001_v2017.vwx Edited July 18, 2017 by Alan Woodwell Quote Link to comment
AlanW Posted July 17, 2017 Share Posted July 17, 2017 @NickSHere is another network that may assist, i have lights attached to a polyline and are adjustable in number, type of lights, intensity etc. HTH Display_Lights_&_Screens_v2017.vwx Quote Link to comment
AlanW Posted July 19, 2017 Share Posted July 19, 2017 (edited) @NickSHi, I have added a worksheet into the fence network that counts the number of palings in each section of fence and calculates the lineal metreage of the palings. Change the paling size and spacing or the height of the fence and the worksheet updates. This only covers a section of the data that can be taken from a network. You can use the principal to develop your own worksheet. HTH Fence_Sq_or_Circ_001+Worksheet_v2017-170719.vwx Edited July 19, 2017 by Alan Woodwell 1 Quote Link to comment
NickS Posted July 19, 2017 Author Share Posted July 19, 2017 Hi guys, Thanks for all the assistance! I haven't had much of a chance to play yet, so will update you guys once I do Quote Link to comment
the frog Posted August 8, 2017 Share Posted August 8, 2017 (edited) hello all Thanks to DomC my frame is working well. I have started to carve the frame. Here comes the tricky part. To make it work I use the duplicate along path via symbols. My frame is built via path extrude. So the object I want to cut is from path extrude and the cutting object is coming from duplicate. When I apply the solid Boolean node (substract) nothing happens. I have all my objects but no cut. Of course to be sure I wasn’t making mistakes I tried with normal objects and it worked. Are the objects built from duplicate or path extrude unbreakable? Edited August 8, 2017 by the frog Quote Link to comment
RAschulz Posted April 22, 2020 Share Posted April 22, 2020 Hi there, I tried to modify @Marissa Farrell s dupSymAlongPath.vwx-file as I was looking for a similar thing as Nick here. As I am pretty much "ok" with VW (about 2 years of 2D and a bit of 3D) and bloody beginner with marionette as my office just bought the architecture version. For a job I am designing a chandelier and I wanted to see multiple options to compare before getting into the details. I found the "duplicate along path" command but it didn't#t work out the way I wanted as I need to rotate while placing and need to calculate the amount of objects I want to place before doing it etc. I got the whole thing to the point where I can place my object of choice on a circle. Also I played around until I didn't have the last one sitting on the first etc. But now I#m still having my objects which I placed 60 on a circle sitting another 60 times on 0,0 for some reason. Can anybody please give me a hint what I am doing wrong. That would help me very much. thx R placing symbol on circle.vwx Quote Link to comment
Michael Siggers Posted December 1 Share Posted December 1 On 7/17/2017 at 2:21 PM, Marissa Farrell said: @NickSHere's the simplest script that shows how to place a symbol along a curve at equally spaced intervals, to get you started. The important thing is to ensure that your path is a NURBS curve. I'd be more than happy to give you further direction if you need it dupSymAlongPath.vwx Hi @Marissa Farrell Apologies for jumping in on this thread, but I'm hoping you can help me. I am trying to figure out how to duplicate an item along a path while also scaling it up very slightly each time. As such I cam across this thread and your Marionette, but need to try and no figure out how I add the scaling element. Kind regards Mike Quote Link to comment
