david p Posted March 10, 2004 Share Posted March 10, 2004 Hello- Printing on the HP deskjet9650 I have come across a little problem that I would like to correct. We are running VW 10.5.1 and downloaded the latest upgrade for the printer. The Problem- The "Set Print Area" is set to a D size sheet and the "Page Setup" is 11x17. VW9 we have no problem matching the sheets together, but in VW10 there is about a 3/8" gap that is missing from the prints. I have tried adjusting the margins with no-luck. I have called VW a few times, and I have called HP. Whats going on here? Quote Link to comment
Guest Posted March 10, 2004 Share Posted March 10, 2004 David, Are you setting the "set print area" to "One Page"? Quote Link to comment
david p Posted March 15, 2004 Author Share Posted March 15, 2004 Mark, No. I want the final prints to be put together as a D size sheet, so we can do a check set before sending them to the printer. Quote Link to comment
