CraftyCat Posted July 14, 2017 Share Posted July 14, 2017 Why do some 3d objects fade into a texture e.g. flooring, even when brought to the front? Quote Link to comment
markdd Posted July 14, 2017 Share Posted July 14, 2017 Could you post a screen shot to help explain? Quote Link to comment
CraftyCat Posted July 14, 2017 Author Share Posted July 14, 2017 Think it may be the lighting? see screenshot. Quote Link to comment
markdd Posted July 14, 2017 Share Posted July 14, 2017 What is the blue object? Very hard to tell what is going on. Could you post the file or copy and paste the objects into a new file and post that instead? Quote Link to comment
rDesign Posted July 14, 2017 Share Posted July 14, 2017 (edited) Judging by the tapered edges at the right-side of the 3D 'white' box it looks like it is intersecting with the 'blue' surface/ floor. You can still see the highlighted orange edge of the box at the right-hand side of the image. Bringing objects to the 'front' has no impact on 3D objects that intersect each other. Edited July 14, 2017 by rDesign Quote Link to comment
CraftyCat Posted July 17, 2017 Author Share Posted July 17, 2017 OK this seems to be happening to all 3d shapes, am I doing something wrong? Quote Link to comment
Kevin McAllister Posted July 17, 2017 Share Posted July 17, 2017 As rDesign said, you have one object intersecting another. I've attached an example image. Stacking order (Send to Front etc.) doesn't affect placement in 3d space. For us to help us further you'll need to include a wider screen shot since its hard to tell from a small detail how to help you. Kevin 1 Quote Link to comment
CraftyCat Posted July 18, 2017 Author Share Posted July 18, 2017 The grey pole won't go in front of blue shape. Quote Link to comment
markdd Posted July 18, 2017 Share Posted July 18, 2017 Hi Are these 3d objects? If they are then how they relate to each other in terms of visibility will be based on their relative Z heights. Why not post your file, or if you prefer, then cut and paste the problem objects into a blank file that we can download? Then we make really constructive suggestions that will help you progress. Quote Link to comment
CraftyCat Posted July 18, 2017 Author Share Posted July 18, 2017 I have attached file here, the steps just blend into the background, same happens with png image prop i import. VW_Problem_Fade.vwx Quote Link to comment
markdd Posted July 18, 2017 Share Posted July 18, 2017 Hi It seems you have many objects duplicated across both layers. This will cause confusion when trying to understand what is going on. The first thing I did was to put the roofs into a separate class so that I could hide them. This enabled me to see much more clearly what is going on. The steps you refer to are blending into the wall because they are indeed placed so that they intersect the wall behind. An easy way to see this is to look in Top view and then it becomes obvious. Maybe try and view using wireframe more. You can see a lot more of that kind of problem with this mode. I model primarily in wireframe and constantly switch back and forth to OpenGL to check how things are looking. (Shift, cmd-G and Shift cmd-W are the shortcuts that make it really quick to do this.) If you want to model in Open GL all the time, then try using the X-Ray mode (B key pressed down will reveal the wireframe behind the OpenGL textures) This is fantastically useful. There are quite a lot of 2d objects on the drawing that are obscuring the 3d geometry. Many others here will have different approaches but I try and keep my 2d only objects on the Screen Plane so that when I am in a 3D view (anything other that Top/Plan) they disappear. You can change this setting in View Menu/Unified View Settings. I can't find the objects that relate to your earlier problem (grey pole/blue shape) Let us know if there is anything else. There will no doubt be other folk who will have loads of advice to offer you. Check out the Vectorworks Youtube channel as well. 1 Quote Link to comment
CraftyCat Posted July 18, 2017 Author Share Posted July 18, 2017 Thanks Mark, is the solution to move the steps so that they dont intersect the wall behind? Quote Link to comment
markdd Posted July 18, 2017 Share Posted July 18, 2017 Or if you like them in the position they are in, then use the Split tool (scalpel) and slice off the section that protrudes through the wall. 1 Quote Link to comment
CraftyCat Posted July 18, 2017 Author Share Posted July 18, 2017 Mark, if you were to set up this file from scratch, how would you go about it? Quote Link to comment
