Customised markings
Guest Frank Brault
Vectorworks' Text styles and Line types may be what you want to look at. Each of these is one of a number of kinds of resources, which are managed in the Resource Manager and accessed from the tool that uses them. Each resource is a definition and each time you use a resource in your documents is an instance of that resource. A resource, once defined, is a drawing component can be used in a file and all instances can be updated simply be changing the Definition in the Resource Manager. Resources can be exported to other files to save time and maintain consistency across your projects.
The entry point for Line Types in the help is here: : http://app-help.vectorworks.net/2017/eng/index.htm#t=VW2017_Guide%2FAttributes%2FDefining_Line_Types.htm&rhsearch=line style&rhhlterm=line style&rhsyns=
The entry point for applying Line Types in the help is here: http://app-help.vectorworks.net/2017/eng/index.htm#t=VW2017_Guide%2FAttributes%2FApplying_Line_Types.htm&rhsearch=line style&rhhlterm=line style&rhsyns=
The entry point for Text Styles in the help is here: http://app-help.vectorworks.net/2017/eng/index.htm#t=VW2017_Guide%2FText%2FUsing_Text_Styles.htm&rhsearch=text style&rhhlterm=text style&rhsyns=
hth,
Frank
