This is a weird problem I haven't had before. For some reason in the attached file, I can't draw on the faces of the lighter extrude when active plane is set to Automatic. I also can't use the Set Working Plane tool on the faces of the extrude. Selection also behaves oddly—I can only select the object by clicking points/edges of the extrude, not the faces. It's like Vectorworks doesn't "see" the faces. This happens with any new geometry I create with any of the rectangle/circle/polyline drawing tools in this file.
If I paste in an extrude made in clean file (the darker one in the attached file), it works as expected. Also if I convert the lighter object to a generic solid, shell, or do any solid/subtract operation it will then work as well.
Has anyone encountered this before? I'm on the PC version of VW2017 with SP4 installed. Any ideas, short of migrating everything to a clean file? I'm hoping it's something as simple as a setting somewhere that I turned on by accident.
I've attached the file in case anyone can take a look and see if it happens on their setup too.
tsw
Hello,
Thanks for any suggestions!
test.vwx
4 answers to this question
