Mattheng Posted July 6, 2017 Share Posted July 6, 2017 I am setting up a new Custom Title Block and have set up all the text to NOT take any attributes from the Sheet Border i.e. the attributes are not set to "by class" It's all fine apart from the opacity which I have set to 50% for a some of the text. It's purely visual because you can't check what it is in the actual Title Block but it looks like everything is 100% Could anyone confirm whether opacity is one of the attributes that you can set in the Title Block that will remain the same. The fonts themselves work ok. Cheers, Matt Quote Link to comment
Andy Broomell Posted July 6, 2017 Share Posted July 6, 2017 It seems to work fine here. As long as the text's opacity is not set to "By Class" it seems to retain whatever opacity I assign it. Maybe attach the file if you can, in case it's a file-specific issue? Quote Link to comment
