Stu Wilson 4 Posted July 4, 2017 Hi Guys, Any ideas on how to put a fence into a site to follow the contours of the ground that slopes away from a building..... as most fences are in real life not infact, single perfectly level lines Vectorworks seems to work in!! Any help would be greatly appreciated Stu 1 Quote Share this post Link to post
CipesDesign 149 Posted July 4, 2017 One way is to use a Wall, set to 6ft High and about 2" thick, and textured with Wood Decking (turned vertically it looks just like fence boards). Draw the wall in Top Plan, on the Site Model Layer, then use the Send to Surface command. Once done, you will need to add some top vertices and adjust their elevation accordingly. Post back with further questions if needed. Quote Share this post Link to post
Stu Wilson 4 Posted July 4, 2017 22 minutes ago, CipesDesign said: One way is to use a Wall, set to 6ft High and about 2" thick, and textured with Wood Decking (turned vertically it looks just like fence boards). Draw the wall in Top Plan, on the Site Model Layer, then use the Send to Surface command. Once done, you will need to add some top vertices and adjust their elevation accordingly. Post back with further questions if needed. Top vertices? have absolutely no idea what that means... at all ! lol Quote Share this post Link to post
CipesDesign 149 Posted July 4, 2017 If you examine a Wall in 3d by Double Clicking, or by selecting the Reshape Tool, you will notice that in it's basic form there are six little nodes (vertices); one at each corner and one each at midspan along the top and bottom of the Wall. These define the Wall. One way to think of these is that they are almost exactly like the "handles" on a 2d rectangle (or polygon); but these are in 3d. If you create a basic Wall, then double click, you will also see that new options become available in the Mode Bar (by the way, all of this stuff is in VW's Help!). The first is Reshape. Try grabbing one of the corner vertices and pull it up or down; watch what happens! The second is "+", you can use it to create a new Vertex by clicking on an existing Vertex and pulling the new Vertex in the desired direction. The third is "-" which is used to delete a vertex (note: some vertices cannot be deleted as they are integral/required for the form of the Object). I recommend that you open a new file and play with these functions. I think you'll quickly get the idea. P Quote Share this post Link to post
mike m oz 372 Posted July 5, 2017 Stu, look at the end of this Vw video. It shows how to do a fence that follows a sloped site. 1 Quote Share this post Link to post
line-weight 772 Posted February 20, 2018 The method shown in that video is not very useful, because in most cases you want a fence to follow a line determined in plan view. You need to be able to project that line onto the surface of the site. Quote Share this post Link to post
Jonathan Pickup 286 Posted February 20, 2018 It surprises me that the railing fence tool can’t be drawn in plan and then simply sent to the surface of the site model to follow it exactly. 1 Quote Share this post Link to post
Jonathan Pickup 286 Posted February 20, 2018 Stu, you can work around this by using property line as a texture bed. Then you can use that to snap along the boundary edge. Quote Share this post Link to post
line-weight 772 Posted February 20, 2018 (edited) 39 minutes ago, Jonathan Pickup said: It surprises me that the railing fence tool can’t be drawn in plan and then simply sent to the surface of the site model to follow it exactly. Yes, that would make life a lot easier and would seem like a fairly obvious functionality to provide. Edited February 20, 2018 by line-weight 1 Quote Share this post Link to post
line-weight 772 Posted February 20, 2018 39 minutes ago, Jonathan Pickup said: Stu, you can work around this by using property line as a texture bed. Then you can use that to snap along the boundary edge. My workaround was to project a polygon down to the site surface, then draw the fence snapping along its bottom edges. Quote Share this post Link to post
AlanW 527 Posted February 20, 2018 Hi, Its a shame that the AUS/NZ fence tool hasn't been incorporated into the full VW rollout, it allows send to surface. Also is attached a Marionette file that sends a fence to a terrain may assist in the interim. Send_to_surface_004Cv2018.vwx 2 Quote Share this post Link to post
Boh 461 Posted February 20, 2018 2 hours ago, line-weight said: My workaround was to project a polygon down to the site surface, then draw the fence snapping along its bottom edges. If you then 3d move the 3d poly the height of the fence you then have a line to snap to get the top of the fence a constant height above the site. This works for the wall tool, not sure about fence tool - need to try that... Quote Share this post Link to post
line-weight 772 Posted February 20, 2018 1 hour ago, Boh said: If you then 3d move the 3d poly the height of the fence you then have a line to snap to get the top of the fence a constant height above the site. This works for the wall tool, not sure about fence tool - need to try that... It's not necessary for the fence tool as it maintains a constant height, unlike the wall tool. Quote Share this post Link to post
line-weight 772 Posted February 20, 2018 1 hour ago, Alan Woodwell said: Hi, Its a shame that the AUS/NZ fence tool hasn't been incorporated into the full VW rollout, it allows send to surface. Also is attached a Marionette file that sends a fence to a terrain may assist in the interim. Send_to_surface_004Cv2018.vwx Looks like that tool lets the top rail be below the top of the vertical pieces which is also handy. Quote Share this post Link to post
bob cleaver 31 Posted March 1, 2018 Alan, your work is incredible, thank you for sending the file Quote Share this post Link to post
