Code Completion
Google didn't turn up anything possibly due to bad search terms on my part.
Is there a 3rd party python code editor that features syntax highlighting and code completion or vs.python?
The function documentation is hard to find things in but I reckon I could get very close with a few keys with code completion.  Certainly, works in xCode and Swift foundation to find the right function.
Hi Matt,
any Python-IDE can do this.
You can either put the vs.py next to your other py modules or better add a search path to the project that links to a folder where the vs.py is located.
Then you have to import it in the modules where vs-functions are called.
import vs
I use pydev for eclipse. The search path can be added in the project properties.
595b4aea75f86_Bildschirmfoto2017-07-04um09_58_52.png.29704ada90b96da76be7ac686b06d662.png
  • Like 2
